Chisel Plowing Video
oliverkid
Mother nature finally decided to quit being a @$#% and guys here in Micigan are running around the clock getting ground fit. Some are starting to plant, but the ground is still a little cold. Supposed to get up into the low 80's and rain tomorrow so I would say by Sunday you wont be able to throw a rock without hitting a planter.
Chisel Plowing
Dont have anything to no-till with. Around here spring chisel plowing is fairly common. Weather and time in the fall generally dont let guys get to much done when harvest is finally done.
(quoted from post at 09:57:16 05/08/14) Mother nature finally decided to quit being a @$#% and guys here in Micigan are running around the clock getting ground fit. Some are starting to plant, but the ground is still a little cold. Supposed to get up into the low 80's and rain tomorrow so I would say by Sunday you wont be able to throw a rock without hitting a planter.
Chisel Plowing
I just checked the Summer forecast, and they said when there is as much ice as we had on the lakes this past Winter, we will have below average temperature this Summer.
