Anonymous-0
1750 Power Steering Leaks
My 1750 has developed an oil leak at the base of the radiator. At first i thought it might be one to the cooling lines to the oil cooler since the bottom fins of the radiator is wet from oil. After capturing some oil I could see that the oil is hydraulic which would indicate a leak in the power steering just under the radiator. How do I get at that location?
According to my shop manual the radiator has to come out. Before I get too far with dismantling I thought I would see if there is any words of wisdom here.
Do the power steering lines get close enough to the radiator to cause oil to spread over the bottom of the radiator fins?
Thanks
PaMnd
Thanks
PaMnd
