Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Changing hydraulic oil on a 1650
Centex Farmall
04-30-2014 20:49:00
Question on hydraulic oil change on a 1650. I know it has to be pumped out, but does it matter if I use one of the remote lines or should I use one of the ports on the hydraulic unit?
Also, is the PTO unit lubricated with gear oil from the trans or does it use hydraulic oil?
Chief 83
05-01-2014 18:28:51
 Re: Changing hydraulic oil on a 1650 in reply to Centex Farmall, 04-30-2014 20:49:00
Just changed mine in a
1550. I used the port on the side as per the manual. Plastic barbed fitting and about 4' of cheap vinyl hose. Worked great, better than expected. Only ran the tractor for maybe 2 minutes. I do think a hyd outlet would work.
rrlund
05-01-2014 06:29:41
You could buy one of those little pumps that go on an electric drill,drop a small hose in the fill hole and suck it out that way.
Kell
04-30-2014 22:05:53
PTO is lubed from transmission.
Rustytractorguy
04-30-2014 21:23:53
We have used a remote on our 2-70.
Copyright © 1997-2015 Yesterday's Tractor Co.
