Oliver 70 Guages
James Stark
New User
Hello Everyone,
I am restoring an 1944 Oliver 70 tractor. I bought new gauges and would like to know where the oil sensor and water temp guages connect to on the engine block.
Thanks Jim
If my memory serves me right, when sitting on the tractor the water temp goes to the hole on the left rear of the block about midway up the block. You may need to put a reducer in the block to fit the fitting size on your gauge. The oil pressure comes from the right side of the block about midway from front to back and threads into a tee there.
