Mike(NEOhio)
- Location
- Newbury, Ohio
At last got the 1550 out. It started with a touch of the key and no choke, ran great. I drove it down the lane between fields to the bottom of the hill and back up in 4th. When I got back to the shed I noticed water coming off the front end. Water pump leaking bad. Also noticed the end of the steering gear where the line connects moves up and down before the tie rods move. Is it supposed to float or should it be a solid mount in the pan?
On the plus side, three point seems to work right, HP works and power steering feels OK. Where's a good source for the water pump?
