3 speed and tub question
2-150 that we converted to a Hercules motor, the three speed started leaking after about 10 acres of field work. It leaks right where it goes into the rear end. Are there seals in there? If so to change them we"d have to split the tractor again huh. We built the frame for it, does anyone know of a tub that would bolt from 2-150 rear end to Hercules motor?
YES THERES SEALS IN THERE REAR SEAL ON HYDRAUL AND A SEAL BETWEEM HYDRAUL TAIL SHAFT AND INPUT SHAFT .IF ITS LEAKING HEAVY OIL IT COULD BE INPUT SEAL , IF ITS LEAKING LIGHT WEIGHT OIL ITS REAR OUT PUT SEAL , EITHER WAY YOU HAVE TO SPLIT IT
YES THERE IS A O-RING UNDER THE COUPLER GEAR AND A SEAL ON THE COUPLER GEAR THATS YOUR PROBLEM , UNLESS YOU HAVE BEARING GOING BAD TO LET THE SHAFT MOVE A LITTLE BIT AND LEAK
