1655 hydraulic seals
Anonymous-0
I have a 1655 with a loader. I continually have the loader creeping down. I have determined the loader seals are not leaking, and the tractor hydraulics seem to be the cause. The left side hydraulics creep down faster than the right side. Is it a complicated fix to put in new seals? And where exactly would one start?
Here is where I would start. Put a 3000PSI gauge on a coupler and insert it in each hose end. Deadhead the system and see how quickly the pressure drops. Your ball checks may be leaking or you may have other problems. All your valves are in the top cover so the problem is easy to get to. Questions?
