Help a dummy - Oliver 88 Belt Pulley
ShepFL
I cant figure out how to get this thing moving. Looked all over for a pull rod etc.
Rig has PTO near rear of seat, transmission shifter and 2 levers for hydraulics.
Thanks in advance.
Should be a knob right along the left side of the steering column. If there isn't it must be missing. Unless it's a real early one,the rod will be bent 90° and the knob will be pointing down.
Nothing like that on this rig. Guess I will pull dash off and look for connector and fab up a rod.
You should be able to see the arm on the gear box by just taking the left side rear side shield off.
Since that tractor has Super sheet metal does it have a belt pulley shifter rod from a Super as well? If you have a smaller rod close to the starter rod check it, it may be the rod for a Super. By the way you have a serial number for that tractor? did you get the miss problem in the engine solved?
Sir -
Have not got the miss solved yet. Been working to get this Possum in the Park festival going.
Also planting tomatoes, peppers, squash etc.
Will focus on it this wx or next.
Thanks for tip on the rod, will check there but don't recall seeing it.
