1850 Hydraulic pressure
Anonymous-0
I'm looking at purchasing a 1966 1850 with the Perkins engine and was wondering what the hydraulic capabilities of theses old tractors are? I need to run my new Holland 846 round baler and am not sure if this will have enough pressure to raise the end gate? My old Farmalls won't do it and they run about 800-1100 psi...Does anyone know what they run at if everything is working properly?
Not sure how much pressure but I know its more than the old 350, 400, 450 Farmalls put out. They will open the gate but only if done while pushing a bale out at the same time. What do you mean by "open slowly"? Olivers valves make it hard to feather the hydraulics?
Had an 846 baler and used to bale exclusively with our 1650.All day long,without a hitch.Been a while,if I remember right it had springs you could adjust on the gate?Might be set too tight.
