TractorLinks.com
Show Parts for Model:
Oliver 550
chucksoliver77
04-24-2014 15:00:37
Is possible to double up the oil seals on the brake cross shaft?
Thanks in advance, Chuck
Chief 83
04-26-2014 17:22:47
 Re: Oliver 550 in reply to chucksoliver77, 04-24-2014 15:00:37
A while ago a guy indicated he had a leaking seal also and the shaft was slightly scored. He indicated that he put the seal in backwards which then caused it to ride in a different place on the shaft. Since there is no pressure (at least I don't think there is) it might work. A bit unconventional but hey if it works it works.
chucksoliver77
04-26-2014 08:10:52
mr.precision, I got the seals from Chavin Equipment Corp. near Nassau N.Y. 518-522-9307. Good to deal with and ships promptly. Chuck
mr.precision
04-27-2014 06:12:55
 Re: Oliver 550 in reply to chucksoliver77, 04-26-2014 08:10:52
Quoting Removed, click Modern View to see Thank you, Chuck.
chucksoliver77
04-26-2014 05:22:28
Super 55, My shaft is nice and smooth so I bought new seals from a different source to try. The seals I put in last spring never leaked a drop until it got cold. Thanks , Chuck
mr.precision
04-26-2014 07:02:05
 Re: Oliver 550 in reply to chucksoliver77, 04-26-2014 05:22:28
Where did you locate the seals?
My 1955 super 55 has the same leak on both sides.
Thanks
Mike
Super 55
04-25-2014 23:56:47
No the recess is only deep enough for one seal. I would take out the old shaft and have a new one made. It's only a straight shaft with a couple of key ways. Shouldn't cost much to replace. I got lucky. When I took mine out, a friend who is a machinist had a bar of stainless and made one for me. Will never wear out!
el6147
04-25-2014 05:46:34
I dont think so, I worked on a super 55 for a customer a year ago and the cross shaft was rust pitted so I machined a new shaft and I believe I was only able to install one seal on each side. other questions can be directed to my email.
