2-135 three point
since i"m still new to the white tractor line i"m still learning lots about the tractor. one thing is the three point and remote cylinder hook ups. should the three point go down when the trator is not running when you put the lever down? and should the remote cylinder not also go down not running? noticed with my plow this weekend, when i shut the tractor off, the 3 point would not go down, neither would the cylinder on the plow. different that my green tractors.
thanks
Gary
  Both need hydraulic pressure to unseat the lowering check valves.  Oliver/White tractors do not have designed three point leakage as the green tractors with yellow wheels.
