1600utillity
twalcutt
I have been working on my latest project all week everything is going well having an issue with the power steering it turns to the right as it should but turns hard to the left the tractor has set not running for quite a while any ideas??
Stick a pressure gauge into the port on the flow divider and see what pressures you have turning both ways. Then jack up the front end and check it the same way.
