White 2-105
M Bray
The trans. lube light comes on when at an idle. But will go out at about 1000rpm. If ran for a sometime needs to run about 1500 rpm to keep it off. Any ideas? Hopeing it's the relieve valve or something simple. Thanks for any help.
Also keep the transmission in the lower neutral when the transmission is in neutral. As has been mentioned ,unscrew the sender and check the pressure.
