1650 clutch
toolz
Need a little advice on the clutch in the 1650 from the last post. Pedal feels normal, but it will not disengage. Been sitting at least 10 years. Could it be rusted to the PP or flywheel enough to do this? It could only be one or the other since the pedal feels good. Worked fine when it was parked. Anything else to check?
Remember early 1650 tractors used an organic clutch later ones used a button clutch. Get your heavy duty log chain out.
Sometimes you can hook it in a higher gear hold the clutch Pedro down and make it. Pull hard. When you park it for a long time block the clutch Pedel down.
