cmeador1984
OK so ill try to make this easy to understand, I have a bad ring and pinion on my E3 so I purchased a parts tractor that is a few years older (not sure on exact, frame was too rusted to read numbers) Mine is a 1950 SN 26,843 which should put it at a 1950, it has open steel brakes at 2-5/8 wide. The parts one I'm assuming to be a 46-47 with the closed brake system.
after swapping the ring and pinion and bull drives I found that the bull drives are too small in diameter, so my brake drums don't go on all the way without hitting the bolts behind them that hold the flange. I dry fitted my Original bull drives and they fit but hit the back of the ring gear barely due to the design.
All in all it looks like I just cant use a mix of old or new, but also cant use the band/enclosed brake bull drives/ring/pinion with my newer open shoe type.
My question is. There is a guy in MI who has generously offered me parts at a fair price, His aret he open type, but the narrower steel (not cast) brakes... If I get his whole setup will that work in my tractor WITH THE FACT that I just need to order narrower brake shoes?
this is the one I installed from the parts tractor, see how it has the ribs cast into it, the bull pinion shafts just barely touch the castings.
