I have a 310D with turbo and it was on the grain vac and died as if someone shut it off. Cranks fine. Fluids all OK. I can get diesel to the pump, through the pump and to the injector (only cracked one injector so far). Opened the little window in the pump and the mark goes around OK. Lots of diesel flows.
Seems to be good compression. No white smoke at all. I've ethered it a little and it won't start or even rattle on ether.
Pulled the air cleaner and it is only a year old and maybe 100 hours. Pulled the outer but didn't pull the inner, but it looks clean.
Ideas?
Ideas?
