Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: cockshutt 30/e3 differential swap
cskent
04-16-2014 17:33:48
There is a break at serial number 27689 and different thrust washers were used to set the thrust. If you use the washers that are with the doner it should work. Try to get a parts manual that shows both set ups, it only shows one differential gear. The one I looked at is from a 1955 parts book. See if you can check the backlash in the bearing which should be in the service manual. I hope this helps
