Super 77 Industrial rear rims
Alan K
Are there any other brands of tractors or industrial equipment that use the rear split rims like is used on the Super 77 industrials? I have a tire going bad, the rim is rusted bad and...I cant get the center hub that holds the rim off of the tractor. I think they are 12 X 24s. Any suggestions?
Alan K do you have a place that has old road graders wheel is same on 112 cat grader. Had to get 4 for a 77 ind. even the lock ring was riveted on the same payed 50.00 each with third thread tires they hadn"t had calcium in them so was lucky So Ill Boco
Thank you for your reply. Im not sure if there is a place near by but having a number of what to check for helps a lot. Wasn't sure if any others were the same. Any ideas on getting a stuck center off of the tractor to remove the wheel? Thank you again.
