OK, can you put a 1000 pto on this tractor? do you use the top port? Wondering, if Yes, do some people have them both hooked up?
Matt
The top 'port' is a reverse rotation engine speed pto for I think
irrigation.
The dual speed pto's have a shifter on the lower right of the rear
case cover with a setscrew screw bolt in the bottom.
To make a dual speed pto you change the center hub in the
lower gears, add the missing lower gear (top is in there) and
install a shifter. You also need a 1000 rpm shaft. I changed a
1950T like this.
I am assuming that there isn't some oddball single speed unit
like an 1800 might have.
RT (my 2 cents)
