Zach Scherf
I put a white multi fuel in the white 2-150 we have. Swap was hard but I got it done and looks good. Only one problem, the engine took a lot to bleed it. Once I finally got it bleed it started at 1500 rpm and I let it run for about ten minutes. Then it suddenly cut out. After topping all the oils off I started it again at the same throttle, but, as before it took a hot of ether then ran fine for another few mins then it cut out again. It won"t run below 1500 rpm, it dies. I know I have a fuel problem, any ideas? I have good flow to the injector, it ran good before sitting a year, I already installed a new fuel pump and fuel filters, please give me ideas of what to check next!
