update on 1555 diesel
bv
Got my engine torn apart today, 5 of the top piston rings broken and spun main bearing other than that looks pretty good, if this block can't be repaired where can you get a block or engine. What is the difference in the 1655 engine? Are the AGCO engine kits built in the USA? Thanks again.
My 1555 frame engine bolt holes were drilled about an inch forward for 1650 engine. The reason for that is input shaft and pto shaft are to long. I had trimmed pto and input shaft off on my first engine swap, I've replaced input and pto shaft so drilled frame. If you go to the search box and type in I love my... you will see my 1555 with 1650 gas engine with my neighbors 4 bottom White plow. It pulled it but hydraulics were less than ideal! Greg
