1550 diesel
Chief 83
I finally have all of my parts coming to fix the pto issues--at least I hope so. While I'm at it a change in fluids is also necessary. I need to change the hydraulic oil. Is the only option for draining to connect a hose and run the motor to pump it out? I'm too far apart to run the motor at this point so I'd like to drain it conventionally. The owners manual is not very helpful.
Stick a small hose down in the fill hole and suck it out with a small pump,mechanical or manual.
