Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
770 hydraulics
mtrengo
04-01-2014 17:23:23
Well looking for advice here. Had trouble hooking up remotes on my haybine but had a cylinder on my discs that the oliver would run . I switched the haybine to the same pioneer ends now I can't plug them in . I did also change the hydraulic oil in between.
J. W. Schwiebert
04-02-2014 06:46:19
 Re: 770 hydraulics in reply to mtrengo, 04-01-2014 17:23:23
Is there a load on the cylinder? Remember has check valves in the hydraulic system that will trap fluid pressure.
mtrengo
04-02-2014 14:20:52
 Re: 770 hydraulics in reply to J. W. Schwiebert, 04-02-2014 06:46:19
Thanx for input but I tried with no load and tractor shutdown . I've been fooling with equipment for 35 years ,this is my first oliver though.
Row Crop
04-02-2014 03:44:29
I figured out years ago it's always easier to plug in hydraulic hoses to the tractor if you shut off the tractor first.
Mike in MI
04-01-2014 18:43:37
Not sure if this could be your problem? Sometimes right after I start my 880 I can't plug in the couplers. Had to let it sit for a while.
Mike
Copyright © 1997-2015 Yesterday's Tractor Co.
