Need help and any advice on rebuilding 1600 PTO clutch. Engagement lever has vibration and knocking, did some adjustment on it and took off cover, to my notion throw out bearing seems sloppy. Plates don't look all that good. Looks like all the shims are there.
Don't think any were every removed to adjust clutch. I have a repair manual, but talks about pulling the whole unit out and using a press for disassembly which I don't have. I don't think the bearing or seal in the housing are bad. I'll admit I'm an rookie on this kind of work.
