Bill in Eastern WA
My White 2-70 has smoky exhaust, has a kind of "wet" appearing stack and I believe could even be getting a little diesel in the crankcase. All this leads me to believe I have an injector that is leaking. I purchased a 1655 shop manual that describes process of removing and servicing injectors. It also mentions an injector tool and cleaning kit. So now I have a number of questions.
1. Do I really need all these tools?
2. The manual mentions discarding carbon-dam seals and compression seals. Can I still get these and does anyone have part numbers?
3. Looks like there are also tools for reinstalling these seals.
4. Seems like I have seen replacement injectors for sale around $60.00 dollars, does it even make sense to try and work on these injectors or are they inexpensive enough to just replace.
5. Can you get the injectors out without removing the exhaust manifold?
6. If buying the tool kit is necessary, where can I purchase?
7. Should I just remove all of them and have them tested or is there a way to figure out which one is giving me trouble without disturbing the others.
Any advice on this would be great.
Looking forward to getting this old tractor to running better.
