Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
e3 pto clutch plates
jonO
03-28-2014 12:00:46
174.124.252.139
I picked up an e3 last spring, previous owner said pto was starting to slip the last time it was on a dyno. Disassembled it today. there are different thickness of shims in each mounting tab. Plates don"t look to bad to me. Looking for advice on removing shims or just replace. PTO will only be used/in tractor for dyno work. Tractor is supposed to be 50hp
[Reply]   [No Email]
Phil Heisey, Harleysville
03-29-2014 04:23:02
72.94.62.64
 Re: e3 pto clutch plates in reply to jonO, 03-28-2014 12:00:46
Hi,
Originally, the unit should have had .050 total shims. It could be 5 @ .010 or 1 @.050.
I would remove ALL the shims, if you had NO SNAP FEEL AT ALL!!
We have the 5 pc. new friction disc/steel spacer plate pak parts on stock here.
Phil Heisey
215-256-8651
[Reply]  [No Email]
Mike(NEOhio)
03-28-2014 16:03:45
162.40.57.21
I had that problem with one of mine. I put it in a vise and turned it with a bar, both engaged and disengaged, and tried different shims until it "felt" right. It's a '46 so it has a lighter duty clutch and no brake. It works OK but I usually only run a tedder behind it. I have never been able to find a spec on how to set that clutch.
Who told you it was 50hp? If that's true I'd love to know how it's done. Be careful putting it together. Be sure the discs with the internal notches don't slip off the spider.
[Reply]  [No Email]
jonO
03-28-2014 17:03:12
174.124.252.139
 Re: e3 pto clutch plates in reply to Mike(NEOhio), 03-28-2014 16:03:45
really no snap right now. its a 48 w/o brake, not sure if its the original pto or not.
[Reply]  [No Email]
jonO
03-28-2014 12:37:22
174.124.252.139
Thank you for your ideas. I have pics but it won't show them, everything was pretty clean, nothing looks burnt or black. I think that Im going to take a few shims out and give it a try. The pto hasn't been in the tractor in a number of years.
[Reply]  [No Email]
mab570diesel
03-28-2014 15:57:02
76.6.166.207
 Re: e3 pto clutch plates in reply to jonO, 03-28-2014 12:37:22
start with taking one out it makes quite a bit of difference. two would make quite the difference as J.W.S. said you want a good snap.
[Reply]  [No Email]
J. W. Schwiebert
03-28-2014 12:23:54
209.143.33.142
How much snap do you have on the handle? 40 Horsepower at what RPM? That is an Auburn clutch I would need to do a little looking to see what it would take to make it the same as a 40 clutch.
[Reply]  [No Email]
duane o.
03-28-2014 12:11:05
162.106.4.145
Holly that must be highly modified to make 50 hp. Mine was 25hp on the drawbar and 29 hp on the pto with 100 rpm increase in engine reves so its legal for vintage tractor pulls when i sold it. Duane o.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
