Oliver 770 Paint
What is the correct color for the white on a 770. I am coming up with clover white. Is this accurate? Is there anywhere other than automotive supply to get the correct color? This is a work tractor so the finish does not need to be perfect but I do want the correct color.
Yes definitely Clover White. It's a real pale green. You can get it from an Agco dealer. I thought I had a paint number for it,but when I tried to open the file in my computer it said it was empty. Somebody will have it.
To the left in the research and info section on this site there are paint codes for what info your looking for. But meadow green body and clover white for wheels and grill are correct. Duane o.
If you have a vansickle paint supplier near you, you can custom order clover white from them. CML-0010 I believe is the correct code. i've painted a couple of tractors with it, if you are going to just work it, it will do just fine for you, color is very close too. Pricing is reasonable, something like $12 or so a quart.
You can also get clover white from Agco, but it is very pricey these days. Last I bought several years ago was something like $30/quart.
The PPG number from the HPOCA site is DAR46536. I cannot find the martin senour number, but my local Napa store has the paint chips and you can just look for it in there.
PPG - DAR 46536
If you have a FinishMaster near you, I have the Oliver Streamline and Fleetline colors on file in their computers. Green's,(3), yellow, and red.
