Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
1850 head gasket
03-23-2014 15:34:25
This head gasket looks a little different than the old one. Gasket set from advantage engine parts. I just want to be sure it is correct before I reassemble. Thanks
Block 354U64443
Head 37116660
Tractor 205 925-557
James 88
03-24-2014 16:08:01
 Re: 1850 head gasket in reply to kevinecwi, 03-23-2014 15:34:25
Give me a call,Have had that problem before may be able to help with parts. PH 574 282 1689 Jim
03-24-2014 13:46:28
Comparing the new one to the old one, it looks like the push rod openings are joined with the water ports.
J. W. S.
03-23-2014 17:41:16
Well I know one thing, the head gasket you took off does not look like the original head gasket either!. I know there were at least 4 different 354 head gaskets. Why did you need to replace the head gasket?
03-23-2014 19:15:38
 Re: 1850 head gasket in reply to J. W. S., 03-23-2014 17:41:16
Engine developed a miss, needed to remove cylinder head and found #3 exhaust valve seat came loose/fell out. This took place quite awhile back, finally this past winter I was able to take the head in for repair/service and am just now in the process of reassembly.
J. W. Schwiebert
03-24-2014 17:01:13
 Re: 1850 head gasket in reply to kevinecwi, 03-23-2014 19:15:38
Did you buy the tractor new? Did it just have one valve seat or all six? Did it have tubes for the injectors? I think you have a 354 that is a little higher up on the ladder than a 354 out of an 1850?
03-24-2014 18:12:29
 Re: 1850 head gasket in reply to J. W. Schwiebert, 03-24-2014 17:01:13
Tractor was purchased used at a nearby Deere dealer about 1979 after our 1750 ventilated it's engine block. Only one exhaust seat was loose, but the machine shop ended up replacing three exhaust seats and one intake seat. He assured me valve protrusion is now within spec. No tubes for the injection nozzles. This engine to my knowledge is original to the tractor unless it was swapped in before 1979.
