hart par-oliver 18/27
The 80 had a variable speed governor, the 18-27 & 18 -28 did not. There are other changes. I sent you an e-mail. I will be down your way in about 2 weeks again. J.
when swhebert came down last fall he looked at an said that it has all the correct parts for the yr an model. air breather i know is a cast iron with letters on it. still havent heard from jw,so if you can remember who repoped the head gaskets sure would be helpfull. dan
Your brother has an early one, like the 5th one built........great find. The tractor should have the cast iron air cleaner cover with embossed lettering on it. Also they had a much different fender decal than the later 18-27's. I had an early one but not as early as yours, it was serial number 100325??? It had the original outline of the fender decal still in place. I checked with Charles City and they had the original decal on file so I had them make me a copy and I used it to make some die cut ones. The hood decal is a straight decal that is yellow and just says ROW CROP. There is no decal on the fuel tank. So if you ever need decals for it let me know.
http://hartparrtractors.tripod.com/index.html
