Loader Valve for 1650 With Cab
Kerwin
I"m thinking of adding a two-spool loader valve using the power beyond feature on my 1650. The tractor"s got a cab, so I"m wondering how others have mounted a separate loader valve in a cab. I"d be interested in seeing any pictures or getting descriptions of what others have done.
Its not an oliver but the concept should work years ago we had a sliding door cab on an IH 826, we mounted the valve on the right loader upright took the levers off the valve and made extention rods that went from the valve to the relocated levers mounted between the dash and right side door. the rods went through lower front window that was replaced with plexi glass so it could have hole drilled in it for the controll rods. this also kept the valve and hoses out of the cab removing both the clutter and oil from a possible leak. sorry i dont have any pics since the tractor was traded off 26 years ago. hope this description helps even with out the pics.
