Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1250 hydraulics
03-17-2014 14:10:53
Have you taken the filter screen out and cleaned it? They don't have a replaceable filter. That big tube along the lower right side of the motor,take the plate off the end and pull that screen out.
I have to tell you,the remotes on my 1365 are slower than I'd like them to be. I've run my haybine with it and I'm not impressed with the speed. I don't think you'll ever get gangbuster speed from the loader off that pump. They made a pump that goes in the rear of the tractor for that. It's the one I showed you in the picture a few posts back.
dick benson
03-17-2014 16:18:36
 Re: 1250 hydraulics in reply to rrlund, 03-17-2014 14:10:53
I did remove the screen on the hydrauloics and washed it. M y screen is just under the left side of the seat. I was told some models used the tranny/rear end for a reservor. My reservore is small, self contained sits on top of the rear housing. An extra small tank was added to increase storage for the loader needs. I don't mind the slow part but if I stand on the arms it will not lift my weight?
03-17-2014 18:03:32
 Re: 1250 hydraulics in reply to dick benson, 03-17-2014 16:18:36
Are you sure about that reservoir being on top under the seat? It should be in the entire trans and rear end. You fill it with that plug just ahead of and to the left of the shift that shows in your picture. If that's not it,I'm lost.
dick benson
03-17-2014 18:58:44
 Re: 1250 hydraulics in reply to rrlund, 03-17-2014 18:03:32
On my 1250 as J.W. said the tranny is not the reservoir. The reservoir is right under the seat. I think it calls for 3 1/2 quarts of ATF oil in the book. The book also says if you are using a loader it is recomended to add an auxilliary hydraulic tank.
J. W. Schwiebert
03-17-2014 18:24:16
Not on a 1250. It is like he said.
03-18-2014 06:49:57
 Re: 1250 hydraulics in reply to J. W. Schwiebert, 03-17-2014 18:24:16
I'm with mab570 on this one then. I'm out.
