Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
1250 hydraulics
dick benson
03-16-2014 18:22:01
63.155.139.205
I just got this unit from a neighbor. He does not know much about it so he is no help. It has a freeman loader on it running off the factory hydraulics using the little pump on the right front side of the motor. The loader lifts up and down but does not have down pressure. I have not tryed to lift a bucket of dirt, which I need to try. The pressure line from the pump to the rear tractor hydraulics has a tee with a valve so you can use the loader when closed or the three point when open. The three point lifts slow and the engine rpm has to be half or better.If I stand on the three point it will not lift. I do weigh 230 lb? Could the oil be by passing thru the loader valve, returning to pump? Maybe I need anothr valve on the return side of the ldr valve? Or might my hyd pump be weak?? Sorry to be so long winded!!
[Reply]   [No Email]
MM CHUCK
03-21-2014 08:56:57
50.104.201.118
 Re: 1250 hydraulics in reply to dick benson, 03-16-2014 18:22:01
The tractor has a open center hyd. The pic. of the valve shows it to be plumbed wrong. The oil should flow thru from side to side. The big plug on the out side should have the return hose attached to it. The return from the valve should power the 3pt. The ball valve is used to shut only when removing loader from tractor to keep oil from flowing out of system. The oil flow should start at the pressure line elbow to the left side of the valve thru valve out right side to the line to hyd. system.
[Reply]  [No Email]
mab570diesel
03-17-2014 21:48:41
76.6.166.207
 Re: 1250 hydraulics in reply to OLWHDA, 03-16-2014 18:22:01
well good luck then as i will be of no help sorry
[Reply]  [No Email]
mab570diesel
03-17-2014 18:23:41
76.6.166.207
 Re: 1250 hydraulics in reply to J. Schwiebert, 03-16-2014 18:22:01
what fluid did you use to fill the hydraulics?
[Reply]  [No Email]
dick Benson
03-17-2014 18:53:49
63.155.185.23
 Re: 1250 hydraulics in reply to mab570diesel, 03-17-2014 18:23:41
ATF. Thats what the book called for.
[Reply]  [No Email]
mab570diesel
03-17-2014 18:18:36
76.6.166.207
i'm with rrlund here in that your transmission and rear-end is your reservoir and those two hydraulic lines that run from the pump should both go into a round canister with two bolts on the side facing the driver that is where your filter and magnet should be i think i would remove that tank on the fender plus it probably gets very hot with the exhaust right there not good if none of this is correct i am also lost
[Reply]  [No Email]
rrlund
03-17-2014 14:10:53
162.250.26.144
Have you taken the filter screen out and cleaned it? They don't have a replaceable filter. That big tube along the lower right side of the motor,take the plate off the end and pull that screen out.
I have to tell you,the remotes on my 1365 are slower than I'd like them to be. I've run my haybine with it and I'm not impressed with the speed. I don't think you'll ever get gangbuster speed from the loader off that pump. They made a pump that goes in the rear of the tractor for that. It's the one I showed you in the picture a few posts back.
[Reply]  [No Email]
dick benson
03-17-2014 16:18:36
71.34.243.135
 Re: 1250 hydraulics in reply to rrlund, 03-17-2014 14:10:53
I did remove the screen on the hydrauloics and washed it. M y screen is just under the left side of the seat. I was told some models used the tranny/rear end for a reservor. My reservore is small, self contained sits on top of the rear housing. An extra small tank was added to increase storage for the loader needs. I don't mind the slow part but if I stand on the arms it will not lift my weight?
[Reply]  [No Email]
rrlund
03-17-2014 18:03:32
162.250.26.144
 Re: 1250 hydraulics in reply to dick benson, 03-17-2014 16:18:36
Are you sure about that reservoir being on top under the seat? It should be in the entire trans and rear end. You fill it with that plug just ahead of and to the left of the shift that shows in your picture. If that's not it,I'm lost.
[Reply]  [No Email]
dick benson
03-17-2014 18:58:44
63.155.185.23
 Re: 1250 hydraulics in reply to rrlund, 03-17-2014 18:03:32
On my 1250 as J.W. said the tranny is not the reservoir. The reservoir is right under the seat. I think it calls for 3 1/2 quarts of ATF oil in the book. The book also says if you are using a loader it is recomended to add an auxilliary hydraulic tank.
[Reply]  [No Email]
J. W. Schwiebert
03-17-2014 18:24:16
209.143.33.142
Not on a 1250. It is like he said.
[Reply]  [No Email]
rrlund
03-18-2014 06:49:57
162.250.26.144
 Re: 1250 hydraulics in reply to J. W. Schwiebert, 03-17-2014 18:24:16
I'm with mab570 on this one then. I'm out.
[Reply]  [No Email]
greygoat
03-17-2014 08:47:11
184.158.35.21
Is that hose, in the bottom photo, being pinched
shut at the bend?
[Reply]  [No Email]
dick benson
03-17-2014 09:22:52
63.155.139.205
 Re: 1250 hydraulics in reply to greygoat, 03-17-2014 08:47:11
No, I moved it to take the photo. soft hose coming from fender hyd tank.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
