1265 Oliver
WVfarmer
New User
I need a block heater for my Oliver 1265. The magnetic universal did not work. Does anyone know where I can get a plug in block heater?
I will need to look it up if no one else posts the number. I would call Rick stairs. Where are you located. A tank type heater would also be a good choice. J. Schwiebert
rick's ag parts 330-466-2164 wooster, ohio he should have just about anything you need for your 1265 good little tractors also import tractor parts has many parts also they are located in canada he is very knowledgeable on those fiats so whichever is closer or would work best for you both i have used before and are easy and reliable to work with so good luck
