pressure lube transmission on 880 oliver
rrrepair
I have a pressure lubed transmission on my 880
Oliver and i need to replace the input shaft. Does
anyone know where i can find one. I need the
complete top shaft with gears. This does not have
a power booster or belt pulley. Please message me
here if you can assist in this.
No those are not the pressure lubed shaft, they are the no pressure lubricated shaft for the early ones. The one im needing is similar to a 1600 oliver without the nut on the rear end of the shaft. They only had pressure lube the last 3 yrs of production of the 880 with the helical transmission.
I have the exact same shaft and problem you have. Lube pump, no power booster. N/A. Six digit part number. Ends in ....49. I will post it later. If mine ever finally fails, I plan to turn down a large bolt to slip inside and weld it in place. Then turn down the coupler and bore out the back side of an impact socket to slip over and weld it on. This will be my new setup. No pto after that but we tractor pull. Might weld a rod around the business end of the socket to keep its shape. Any input on this idea?
You said:
They only had pressure lube the last 3 yrs of production of the 880 with the helical transmission. Where did that information come from? That would make all 880 helical gear transmissions have pressure lube since for practical purposes 1962 was the last year of production. Three years would be all 60,61 & 62 models. All 63 models were for export. I never put lube kits in till the 880 models were out of production.
I had a problem with the low side gear seizing to the shaft on a pressure oiled 880 rear end. My local parts man called several places without any luck. It took me nearly a year of searching before I found a replacement shaft. I have a shaft that could be redone by a machine shop. E-mail me if you would be interested.
