ISO 8.3 cummins
I'm looking for 8.3 cummins want put in 2050 Oliver in located in south east Indiana call or text 513-763-0891 don't have to run just mostly complet thanks
All I can ask is WHY??? An 8.3 cummins will look like a butcher job in there. You will not get everything under the hood. Plus you will have to replace other components of the 3 speed over/under shift to even get it to work. I have done many of these and used the 200HP 5.9engine and makes a nice tractor with a LOT less extra costs. If you would like call me M-F 8-5 CST and i can give you more info on what your up against with the 8.3 563 382 4530
While I would be inclined to put a 5.9 in also, there wouldn't be a thing wrong with putting a 8.3 in. They're not any bigger than a 478, depending on the HP desired and application, the SAE 3 parts could be used so no modifications to the 3 speed would be necessary. With the proper exhaust manifold, putting the turbo in a location that allows the factory air cleaner located in the factory position and eliminating the need to modify sheet metal is not a issue.
Garret, depending on what you want in a engine, I have one out of a White 6195 that has 10,000 hours on it but ran fine every day until they ran the powershift out of oil and decided the tractor wasn't worth fixing.
I would be intrested give me a call some time my number is 513-763-0891 the we go was in a fire and is in rough shape and need the three speed to fix a nother one we workin on I've put a 5.9 in a 1955 cockshutt that had a bad 310 and have a 1755 I getting ready to put one in I just thought I would 8.3 it strait shaft it so it don't get scraped it problyget pulled once or twice just to remind the ih and Jd guys something to compete with
search this forum for "tractor vet"
Dan just did what you are asking about
said it went fairly smooth
Dan is long winded but does get it all explained eventualy
he is from NE ohio
good luck
Ron
