TractorLinks.com
Show Parts for Model:
Re: 310- turbo pressure / turbo swap
jasinpa
03-15-2014 19:16:54
came off a 6BT cummins 359 ci , first version 160 HP dodge truck engine , in reply to the other post did the bigger compressor turbine make a power gain , hows it work in the field?
4010 puller
03-16-2014 20:49:03
 Re: 310- turbo pressure / turbo swap in reply to jasinpa, 03-15-2014 19:16:54
I think that turbo will have a lot of lag, it may make tractor worse than it already is. If you don"t use a TO4 you may try a schwitzer 3lm33
bison
03-15-2014 23:18:34
Put a 15 psi pressure gauge on the intake manifold, that will show you the boost pressure.
You can drill and tap for a pyro gauge in the exhaust manifold just under the turbo for checking EGT's
