1250 Hydraulics
I managed to get the 1250 running today after sitting for 6 years. All new filters and eng oil. The fuel looked pretty good so I added some good fuel conditioner. Took a bit because the primer plunger on the enjector pump seems to be stuck. Tractor runs, very little smoke, and the clutch brakes and tranny works. Only problem is the three point and loader do not function. I had a couple quarts of oil I added with out any improvement. I think it might need more oil. The freeman loader was added and is running off of the tractor hydraulics?
Is there a pump on the back of it like this one or is it running off the one on the front of the engine?
If it's like this one,the PTO has to be engaged.
It runs off the engine front mounted pump on the right side of the motor.There is two lines runing back to the hydraulics under the seat and the loader is teed into the pressure line. It has an extra small hyd tank mounted on the left fender. I think my pics show the tee with a valve.
