sack seat covers and lights?
Anonymous-0
Does anyone know where I can get a replacement sack seat cover for a HP 70?
Also, which are the correct lights and mounting brackets for the HP70 row crop tractor?
should be cast iron bracket with 2 mounting bolts.it looks like a 1/2 a golf ball with a hole to mount the light.I think the light are flat lens 8" drum style
(quoted from post at 14:43:55 03/14/14) should be cast iron bracket with 2 mounting bolts.it looks like a 1/2 a golf ball with a hole to mount the light.I think the light are flat lens 8" drum style
I HAVE A 37 AS WELL. Just wondering if someone had an original light and could put a picture on here.thanks
My information indicates a '37 HP 70 would have used 7" flat glass lights, the same as all later Oliver 70s till the end of 70 production. The head lights on a '37 HP 70 would mount on the cast radiator shell and the tail light mounted on the fender.
