Searching for E3/30 rear end
Tore the last parts of the project down and notice the differential gears are in poor shape, as these can't be found new I'm hoping to find a whole rear end, do not need the transmission, or axle shafts/housings but will work with what you have. Really from what I can see is work out planetary gears as well as teeth chipped on the ring gear. In ohio but can work out transportation. I have found one on ebay but the gentleman isn't even willing to open the inspection covers for pics. Makes me nervous about buying it.
I have a lot of 30 parts here including a whole frame and rear
end. I am in Eastern Ontario, near Ottawa and Massena New
York. Let me know if it is of interest.
Neil
Hey folks, sorry for the delay response, didn't realize you all had replied. I'm in the Cincinnati area, I'm not against a bit of a drive for the right parts/price. Basically my ring and planetary gears are worn, some teeth chipped in the run gear and caused damage to the planetary.. I'm assuming the pinion gear has probably taken a toll as well (can't see it) I figured it may just be easier to find a good rear end with everything there and use it, save me the hassle of trying to shim and restore with already used parts. If you guys could, shoot me a price and ether pics or something about what you have. Mine works and runs but the level of restoration I'm doing, I'd like to find better.
Not so sure if this pic will attach but if so this is what I'm looking for (whole unit) with or without transmission gear box.
