Mike Thompson, Super 55 warning light
super 55
Location
Whonnock BC
Hello Mike, what I was specifically looking for on the warning light was the lens diameter, the diameter and height of the "spool" that holds the electrical cable and the length of the cable. I want to make one up for my tractor for a display. If you have time to do that some day, I would love to try to make one. My email is open. Thanks for any help.
If you put "smv light" in the search window in the oliver forum you can see on 12-01-13 that riverslimj has the pics of a non oem light and cord on this subject. I have one if you want I will measure the lens and post the diameter and cord length for it, it is not oliver, but it is the one pictured.
I would love to help you out but my light is in storage at my farm in Illinois and I am in California. The one that Kent is talking about would work good I"m sure and much cheaper than a OEM light I think the last one on e-aby went for 350.00 and I paid about 250.00 a couple years ago for mine. Actually at the shows out here I have been afraid to display my tractor with the light on it because of sticky fingers. Good luck
Thanks Kent, I found the pictures. However, I think I can fab one that looks more like the original. I do like the idea of the cord already made up. I would start with this light if it is the right diameter or close to it.
Thanks for the reply. I am not in a big hurry, so if you remember next time you see the tractor, I might still be needing the measurements since you are the only person I have found that has one. I understand your fear of light fingered, not pun intended, tractor thieves.
