Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
1550 chain coupler
Roger Mesenbrink
02-23-2014 09:02:37
76.115.93.73
The splines on the chain coupler shaft on the trans side are worn and loose sko a new sprocket will not help with worn splines, any suggestions?
[Reply]   [No Email]
somidan
02-23-2014 18:00:42
204.106.255.12
 Re: 1550 chain coupler in reply to Roger Mesenbrink, 02-23-2014 09:02:37
Do like Gary says or you can weld a used gear from the top transmission shaft of any older Oliver tractor. I used half of the main shaft gear or mechanical lift gear from an 88 on my 1550. Then cut the teeth off that gear. Gets it back to good splines.
[Reply]  [No Email]
dboll
02-23-2014 17:17:05
72.251.115.8
the best but maybe not the easiest fix is to replace it with a good used or rebuilt input shaft, if the sprockets don't run true it will eat cotter pins and I have seen the chain links swing out and wreck adjacent hyd. lines
[Reply]  [No Email]
gary spitznogle
02-24-2014 05:21:58
207.28.145.7
 Re: 1550 chain coupler in reply to dboll, 02-23-2014 17:17:05
Larry"s # is 512-633-5014. Also when I do this I use a clutch shaft out of a 77 or 88 with the same splines to be sure it"s straight, then tach in 4 places so it don"t pull crooked
[Reply]  [No Email]
dboll
02-24-2014 05:45:14
72.251.115.137
 Re: 1550 chain coupler in reply to gary spitznogle, 02-24-2014 05:21:58
as long as a person is in it that far wouldn't it be just as well to r&r the input shaft? Putting splines behind the sprocket is going to want to pull the sprocket at an angle once the splines wear a little which they will do as a result of the point of pull not being in line with the centerline of the sprocket, sounds like a band- ade fix to me
[Reply]  [No Email]
gary Spitznogle
02-23-2014 16:05:06
67.55.184.92
If there is good splines behind the wore out ones Larry sverlack in texas sells a spline you can weld on to new sprocket or a good used one with good teeth.I just done one on 1655. I'll try to find phone # and add
[Reply]  [No Email]
duane o.
02-23-2014 11:17:09
68.149.235.112
Find a" new" to you input shaft thats better than yours or find some shim stock that you can cut to size and tighten up the splines. The coupler must have been loose or a baddly running engine to cause this
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
