TractorLinks.com
Show Parts for Model:
Re: 1550 engine?
Roger Mesenbrink
02-23-2014 08:58:39
Thanks for the info. I will be doing an out of frame overhaul, and sounds like of oversize will be no problem and get alittle more power. It also appear I have some wear on the splines on the trans side shaft where the chain coupler is any ideas or suggestions?
Mike(NEOhio)
02-23-2014 10:02:35
 Re: 1550 engine? in reply to Roger Mesenbrink, 02-23-2014 08:58:39
Overbore sleeves have been going into engines for years. A little more power? Probably, but even std bore will do that if you're replacing worn-outs. As to your post on the chain coupling, if the shaft splines are worn I would suggest contacting Tim at Smitty's Tractor. I just met him last Thrusday, great guy, good advice and literally "tons" of parted out Olivers.
