Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Cockshutt 40 axle seals
Whiskey Bent
02-22-2014 21:48:31
69.77.244.161
Im replacing the axle seals on my 40, I read the procedure in the I&T manual but its very vauge. I pulled one of the axles out but it looks like I shoulda just pulled the hub. Ive read that the hubs can be difficult to get off so should I put axle back in then remove the hub or remove hub with axle out? Does anybody have the torque spec for the inner and outer axle nuts? Thank you.
[Reply]   [No Email]
Whiskey Bent
02-24-2014 18:32:44
69.77.244.161
 Re: Cockshutt 40 axle seals in reply to Whiskey Bent, 02-22-2014 21:48:31
Thanks Phil, where does the O ring go? I looked things over closer and I see another seal on the inner side of the axle where the axle housing bolts to the rear end. It looks to me like this seal keeps the gear oil out of the axle housing and the seal behind the hub keeps the gun grease from going into the axle housing. I have prolly 1/2 gallon of gun grease in housing. So you need to replace both of these seals or you will fill the axle housings with gear oil, so you do need to remove the axle and the hub to do both seals. Just not shure where O rings goes?
[Reply]  [No Email]
Phil Heisey, Harleysville
02-26-2014 14:17:42
72.94.62.64
 Re: Cockshutt 40 axle seals in reply to Whiskey Bent, 02-24-2014 18:32:44
Whiskey,
The O-Ring goes on the axle last before installing to hub. The purpose of the O-Ring seal is to prevent oil/grease from following the threads to the outer castle nut.
I would replace the inner axle oil seal too, while you have everything apart.
Phil Heisey
215-256-8651
[Reply]  [No Email]
Whiskey Bent
02-23-2014 09:32:13
69.77.244.161
2 seals? I only see 1.
[Reply]  [No Email]
02-23-2014 18:30:42
72.94.62.64
 Re: Cockshutt 40 axle seals in reply to Whiskey Bent, 02-23-2014 09:32:13
Whiskey Bent,
The other seal is an O-Ring, Cockshutt Part number TG-9430.
Phil Heisey
215-256-8651
[Reply]  [No Email]
P Heisey,Harleysville, PA
02-23-2014 07:01:46
72.94.62.64
Whiskey Bent,
Remove hub and cap. Torque the outer castle nut to 600-650 ft. pounds.
We have the two seals needed on stock here.
Phil Heisey
215-256-8651
[Reply]  [No Email]
Mike(NEOhio)
02-22-2014 23:03:07
162.40.57.21
I haven't had mine apart but it looks like the flange has to come off to change the seal. Since the shaft is out it may be easier to have it pressed out. As far as the torque, I would just put the nuts back to where the cotter pins are in the same slot.
[Reply]  [No Email]
Ivan Grant
02-23-2014 06:30:24
67.70.131.137
 Re: Cockshutt 40 axle seals in reply to Mike(NEOhio), 02-22-2014 23:03:07
You have to get hub off.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
