Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
White 2-180 Battery Hook-Up
newfarmer9
02-22-2014 18:02:27
216.218.29.251
I took the batteries out of my White 2-180 to charge, and now can't remember which way they should be hooked up. I looked in the operator's manual and the service manual, and they show two conflicting diagrams.
The operators manual has the negative posts of the two batteries hooked together and then grounded to the frame, with a cable running from each positive post over to the starting solenoid (parallel).
The service manual shows the negative post of one battery hooked to the positive post of the second battery (series). The second negative post is then grounded to the frame, and the second positive post is connected to the solenoid.
What is the correct way to hook these batteries up?
This post was edited by newfarmer9 at 18:21:38 02/22/14.
[Reply]   [No Email]
newfarmer9
02-23-2014 11:55:29
216.218.29.173
 Re: White 2-180 Battery Hook-Up in reply to newfarmer9, 02-22-2014 18:02:27
I ended up getting it figured out. They are hooked together in parallel. I just don't know why the service manual would show them hooked together in series???
[Reply]  [No Email]
G1355
02-23-2014 11:51:38
67.224.60.152
They are parallel, here's a picture of my 2-155 which should be the same.
[Reply]  [No Email]
buzzinduzzin
02-22-2014 18:38:27
66.220.92.37
look at the starter and or alternator if they say 12 volt then hook 12v batteries in parallel, or two 6v in series
[Reply]  [No Email]
newfarmer9
02-22-2014 18:21:04
216.218.29.251
The service manual says "Two twelve volt batteries in parallel", which is what I think is correct, but then the diagram shows two batteries hooked in series?
[Reply]  [No Email]
RWT
02-22-2014 18:48:47
50.103.134.54
 Re: White 2-180 Battery Hook-Up in reply to newfarmer9, 02-22-2014 18:21:04
If both batteries have a cable hooked to 'chassis' they were parallel.
A cable running from one battery to the other would be series but I doubt it is like that.
I hope this helps.
RT
[Reply]  [No Email]
bv
02-24-2014 10:19:01
74.174.194.2
 Re: White 2-180 Battery Hook-Up in reply to RWT, 02-22-2014 18:48:47
What is the difference in series and parallel? I just bought a 1555 diesel that has 2 6 volts are the previos owner said it turns over too slow so I want to put 2 12 volts on it so, hook them parellel or in series? Thanks again.
[Reply]  [No Email]
J.Wondergem
02-24-2014 11:01:21
70.194.3.74
 Re: White 2-180 Battery Hook-Up in reply to bv, 02-24-2014 10:19:01
Quoting Removed, click Modern View to see.
I think I'd have the starter check out first and see How .such drag it has.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
