TractorLinks.com
Show Parts for Model:
Re: 1550 engine?
pllr
02-22-2014 15:36:09
why not do a good job, remove engine, replace seals, all bearings, cam, mains, rod, send out crank, probably needs to be ground .010 under, depending on hours, clean oil galleys, complete short block, long as you are going thru the motions...
Roger Mesenbrink
02-23-2014 08:58:39
 Re: 1550 engine? in reply to pllr, 02-22-2014 15:36:09
Thanks for the info. I will be doing an out of frame overhaul, and sounds like of oversize will be no problem and get alittle more power. It also appear I have some wear on the splines on the trans side shaft where the chain coupler is any ideas or suggestions?
Mike(NEOhio)
02-23-2014 10:02:35
 Re: 1550 engine? in reply to Roger Mesenbrink, 02-23-2014 08:58:39
Overbore sleeves have been going into engines for years. A little more power? Probably, but even std bore will do that if you're replacing worn-outs. As to your post on the chain coupling, if the shaft splines are worn I would suggest contacting Tim at Smitty's Tractor. I just met him last Thrusday, great guy, good advice and literally "tons" of parted out Olivers.
