Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Oliver 1755 transmission questions
will-max dairy
02-20-2014 14:13:57
Thanks.
Can you clarify some?
I'm trying to reason out what fluids are used where. Based on the dipsticks/filler locations and such that I know of, I'm assuming:
Obviously, there's engine oil. I have checked and filled that as needed. I use engine oil here. Heavy for summer, thinner for winter, no problem.
There is a resevoir of hydraulic fluid (which I check and fill with the dipstick just behind the seat) that runs the remotes and the steering. I use hydraulic fluid here. I also believe that this revervoir operates the hydraulic brake assist; because pushing the brakes can affect the operation of other hydraulics (bucket).
There is a filler location just above the pto (about waist high) that somebody capped off with half of a beer can held by a hose clamp (no lie...really). I assume that's for gear oil for the final drives to the axles and the pto and such. I haven't added anything here; but I assume it would be gear oil.
Then there is the transmission, which is a hydraulic shift and has this over/under unit. For this, I now see the dipstick near the clutch pedal. Is this the only reservoir of fluid for both the transmission and the over/under? Some references recommend automatic transmission fluid here. Is that correct?
J. Schwiebert
02-20-2014 17:54:36
 Re: Oliver 1755 transmission questions in reply to will-max dairy, 02-20-2014 14:13:57
You said: There is a filler location just above the pto (about waist high) that somebody capped off with half of a beer can held by a hose clamp (no lie...really). I assume that's for gear oil for the final drives to the axles and the pto and such. I haven't added anything here; but I assume it would be gear oil. I think the beer can is the cap for the cover for the PTO control valve. Is there linkage attached to it? If so that is not a fill or check plug. YOU NEED AN OPERATORS MANUAL!!
You also asked:Then there is the transmission, which is a hydraulic shift and has this over/under unit. For this, I now see the dipstick near the clutch pedal. Is this the only reservoir of fluid for both the transmission and the over/under? Some references recommend automatic transmission fluid here. Is that correct? It is the dip stick and fill for the 3 speed over under .Automatic transmission fluid was the fluid of choice but has been superceeded by a good tractor hydraulic fluid like Hy-Tran The transmission is separate and also has its own filter which is mounted under the floor board. I will need to look tomorrow. I don't remember if the fill plug is the same as on a 50 series, It has been 37 years since I filled and checked one. It will take like 80-90 gear oil. Change the hydraulic filter as well. Make sure the micron rating of the filter is 10.
