super 99 fuel pump
JimKS
I am working on a super 99 Waukesha 6 cyl diesel.I am trying to find a rebuild kit or a fuel pump.
The Oliver part # is 7AS-2460-B It also lists it as AC 1539959. I have not been able to find the AC # or a cross referance.
Any help would be appreciated. Jim
Korves has kits, just got one, rebuilt it to find that several pieces of the cam follower broke off sometime.switching to electric pump,so if interested i could sell mine if you have a good cam follower
Ran into the same issue on my s99. I found a pump from an 1800 and installed that although you need to change some lines and it doesnt have a sediment bowl on it like the old one. I changed the arm with the old one as the foot is wider but didnt need to. Hope that will help if you dont want to wire it for an electric pump. Duane o.
