TractorLinks.com
Show Parts for Model:
Re: Oliver 1755 transmission questions
will-max dairy
02-19-2014 07:39:45
Checked the linkage for the over/under last night. The linkage is intact; but there is no "detente" to it. The lever acts as if there are no range positions. I wonder if this is due to a lack of fluid pressure in the transmission.
I also noticed a cylindrical can oil filter on the housing just above where the over/under linkage enters (and towards the rear of the tractor). I wonder if that filter is for the transmission?
What type of fluid is this transmission supposed to have?
Any hint as to the part number of that filter?
will-max dairy
02-19-2014 08:04:16
 Re: Oliver 1755 transmission questions in reply to will-max dairy, 02-19-2014 07:39:45
NAPA's search engine, given the make, model and year of the tractor came of with:
FIL 1307 for over/under transmission filter
FIL 1567 for hydraulic fluid filter
Sound correct?
J. Schwiebert
02-19-2014 13:15:03
 Re: Oliver 1755 transmission questions in reply to will-max dairy, 02-19-2014 08:04:16
Have no idea. There are 2 filters for the over under, but if you are going with the NAPA filter get 2 because the transmission uses the same one. Also use a good grade of tractor hydraulic fluid (Hy tran) instead of the type A.
