Buzzin duzzin
What fly wheel and pto hub did you use on your Detroit swap in your 2-150? Having trouble matching up what we got, the military flywheel there is no place to put the pto hub, so we got a 2-135 flywheel and 2-135 pto hub. Just curious how you went about mounting up the motor to the rear end, it's a little difficult since the 2-150 rear end is its own animal
copied Kinze's design concept: adapter hub bolts to detroit flywheel, then 2-150 flywheel & IPTO hub bolts to adapter. This allowed the trans. input shaft, throw-out brg. etc. to remain stock. switched to a 2-180 double disc clutch at the same time. Brad Maibach gave me some good input.the IPTO hub on a 2-150 is sandwiched between the flywheel & the crankshaft or in this case the adapter hub.a friend of mine has the kinze stuff that we got the concept from . clear as blue mud?
