Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
2150 PTO shaft bent
Mitch Poindexter
02-03-2014 14:41:49
98.196.36.243
When we were re-installing the pto shaft after installing the new motor we noticed a slight bend in the end of the pto shaft towards the back of the tractor. The bend is over about the last 4-5 inches. Not so much that we couldn't get the shaft out, or that we couldn't get it back in, but it has me a little worried. If we did anything, we would just pull it out and put it in the press to straighten the bend, but if it's something I shouldn't worry about, we'll leave well enough alone. Think this is ok, or do I need to work on it some more?
[Reply]   [No Email]
J.Wondergem
02-03-2014 16:49:29
70.210.69.188
 Re: 2150 PTO shaft bent in reply to Mitch Poindexter, 02-03-2014 14:41:49
How many thousands is it out? Might want to have a machine shop spin it and find out, unless you can. I would think with in .004, but I'm no machinist.
[Reply]  [No Email]
jasinpa
02-04-2014 05:52:32
67.234.166.174
 Re: 2150 PTO shaft bent in reply to J.Wondergem, 02-03-2014 16:49:29
if its bent that you can see it , it probably should be replaced , theres no way you can see even .010 of a bend & if it bent that bad it will shake the thing to pieces , maybe a machine shop with a crank straightener could bend it back , but how much will it weaken the shaft? also is it to hard to even straighten may brake? , maybe one of these other oliver guys can add some input
[Reply]  [No Email]
Mitch Poindexter
02-04-2014 06:18:42
216.99.180.5
 Re: 2150 PTO shaft bent in reply to jasinpa, 02-04-2014 05:52:32
Y, I agree. Wonder how the previous owner bent the back end of the pto shaft? Guess some people can break an anvil.
[Reply]  [No Email]
J. Schwiebert
02-04-2014 09:20:39
209.173.169.187
 Re: 2150 PTO shaft bent in reply to Mitch Poindexter, 02-04-2014 06:18:42
So it is bent between the hydraulic pump drive and where it is splined into the PTO clutch? Those 2 places are supports by bearings in both cases the weakest point to me being where the needle bearings are that support the pump drive. How much is it bent? Did you have the hydraulic unit off? How good are those 2 bearings? Has anyone installed pressure lube to those bearings?
[Reply]  [No Email]
Mitch Poindexter
02-04-2014 10:02:46
216.99.180.5
 Re: 2150 PTO shaft bent in reply to J. Schwiebert, 02-04-2014 09:20:39
Really think it's only bent at the pto clutch splines. Without knowing, I'd guess maybe someone wrecked the pto and something came apart?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
